Google Posts
Please advise if the Google review widget can be customized to display google posts from the GMB instead.
This is really important for relevance and connecting the site to the GMB.
I would really really appreciate this.
Thank you Joshuah
Hi @Joshuah, welcome to the forum!
GMB reviews already work fine in our widget, am I right that you’re experiencing issues with fetching your reviews? If so, could you please describe it in some more detail?
Yes thank you reviews widget works fine
I have 2 customization requests if at all possible
  1. If possible can the external url be changed for the (posted on Google) to the review stream of the GMB instead of the contributor.
Example https://www.sandiegohomelender.com/
in the review section
The external url goes to Redirecting
This will assist in local ranking
  1. Please advise if the Google review widget can be customized to display GOOGLE POSTS from the GMB instead of google REVIEWS.
