Google maps - location window width
Hello!
Is it possible to set the width for the location window in google maps?
Best regards
Rakel
Hello @Rakel_Bara! We are so happy to see you with us! Welcome to Community :heart: :wave:
Sure thing, we’ll be happy to assist!
I’ve forwarded your request to our devs and they’ll come up with a solution really soon.
Please do not worry, we’ll keep you updated :wink:
@Rakel_Bara You just need to add the CSS code below to the Custom CSS field on the Appearance tab of your widget settings:
.eapps-google-maps-marker {
  width: 350px;
  max-width: 350px;
Please check it and let me know how it works for you :slightly_smiling_face:
Hi Max
Thank you very much, that worked perfectly :slight_smile: I have another quesiton though. I am trying to use a horizontal line in the description using the
tag but every time I try to use it, it disappears. How can I get it to stay?
Best regards
Rakel
@Rakel_Bara Happy to hear that the code worked :blush:
Could you please specify where exactly you are trying to add <hr> tag? Screenshots would be highly appreciated :pray:
Hi again
It’s in the description - in the editor when I switch to code view. I can enter the tag, but after I switch back the tag is gone.
@Rakel_Bara I’ve tried to add the tag and everything is working fine:
Yes it appears, but try going into the description again and it disappears.
Hi Max
Here is a video where you can see the
tag disappear.
Best regards
Rakel
(Attachment 2023-02-20_19-29-48.mp4 is missing)
Hi again, I just sent you an e-mail with a video, showing the tag disappear.
Hope you can see it!
Ok apparently it is not allowed to send videos. Can you see it here: https://www.legstadaleit.com/hrtag.mp4
@Rakel_Bara Yes, I see the issue!
I am really sorry! Please let me consult with our devs.
I’ll immediately get back to you as soon as I receive any updates!
Excellent! Thank you :smiley:
Hello @Rakel_Bara :wave:
I’ve consulted with our devs and unfortunately <hr> isn’t supported in our Code Editor.
You can try to use this CSS code instead:
.global-styles, .eapps-google-maps-marker-description ul {
  border-top: 1px solid grey;
  padding-top: 5px;
Please check it and let me know if you like what you see :slightly_smiling_face:
Hi Max
The thing is, I have a list of links in the description, and I wanted to put a horizontal line between each link so that each link is clearly defined. I had used the line break tag “br” – but that leaves a space that is too big (in my opinion) between the links. Can that be adjusted with CSS? See image.
Best regards
Rakel
@Rakel_Bara Yes, this CSS code helps you to do this.
Here is how it looks:
Please let me know what you think.
Hi Max
That looks great! Is it possible to make the spacing between the links smaller (the spacing I showed in the image above)? I don’t know if it is possible but if it is, that would make everything look perfect! :smiley:
Best regards
Rakel
Hi again Max
I managed to figure it out myself :smiley:
I used this CSS:
br
{   content: "A" !important;
    display: block !important;
    margin-bottom: 1em !important;
Thanks for excellent support!
Best regards
Rakel
@Rakel_Bara It’s no bother!
Hey @Max is it possible to open the window by default on mobile devices? I have enabled this option but is working only for desktop.
