By default, the location panel in Google Maps is collapsed on mobile, showing only 1 location from the list:
However, if you prefer to have it expanded right from the start, just add this script right after your widget installation code and you’ll be good:
const waitForElement = (selector, callback, step, limit) => {
const currentStep = step || 300;
const currentLimit = limit || 5000;
let remainingTime = currentLimit;
const intervalId = setInterval(function () {
const targetElement = document.querySelector(selector);
if (targetElement || remainingTime <= 0) {
clearInterval(intervalId);
if (targetElement && typeof callback === "function") {
callback(targetElement);
return;
remainingTime -= currentStep;
}, currentStep);
waitForElement(".eapps-google-maps-map-container", (block) => {
const widgetBlock = block.closest("[class*='elfsight-app']");
const isOpened = widgetBlock.classList.contains(
"eapps-google-maps-bar-opened"
if (!isOpened) {
widgetBlock.classList.add("eapps-google-maps-bar-opened");
Got any issues or questions? Describe your use case in the comments and we’ll be happy to help ![]()
