Fullscreen slider on homepage
hey guys
Hope you’re well
I’d like the slider to be full screen if possible
What custom CSS to i put in?
This is the test page:
I’d like the images to appear fullsize:
like this - https://www.jpav.co/
I like the setting i currently have above, but the plugin i used does not allow for random order of images
So on the new page i plan to use the random order setting once i know how to make the images full screen
Thanks so much
I really appreciate it
James
Happy to see you in our Community! Welcome @user9235 :wave:
Sure, I’ll check it with our devs and will get back to you once I receive a response from them :slightly_smiling_face:
Thanks so much
Really appreciate it
Please try to replace the widget’s installation code on your website with this code:
<script src="https://static.elfsight.com/platform/platform.js" data-use-service-core defer></script>
        const WIDGET_ID = '938c7a90-a049-4812-910e-44eac142d44a';
        const addWidget = () => {
            const widget = document.createElement('div');
            widget.classList.add(`elfsight-app-${WIDGET_ID}`);
            setTimeout(() => document.body.prepend(widget), 100);
        if (document.readyState === 'loading') {
            document.addEventListener('DOMContentLoaded', addWidget);
        } else {
            addWidget();
Check it out and let me know if it worked :slightly_smiling_face:
Hi there
Thanks so much for your help, i really appreciate it
It has definitely improved things, but the image now has a blank section below - can this be altered?
Thanks again
James
Oh, I am sorry about this inconvenience!
We’ll double-check things and will get back to you a bit later :slightly_smiling_face:
@user9235 Please try to use this code instead:
            setTimeout(() => {
  const page = document.querySelector('#page');
page.replaceWith(widget);
}, 100);
        } else {
            addWidget();
Thanks Max
Really appreciate your help
Unfortunately copying this code into the ‘code’ section just brings up a blank section?
No images appear at all now
Sorry if i misunderstood the steps
James
Oh, I am sorry, the last part of the code wasn’t successfully copied!
The script tag was missing in the end. Please add this version of the code to your website and let me know if it worked:
            setTimeout(() => {
}, 100);
        } else {
            addWidget();
Thanks so much for the fast reply Max
This worked, but unfortunately It still looks the same (with the cutoff bottom)
Screenshot attached
Thanks
I’ve checked your website and it looks fine in my end:
Could you please check your website in incognito mode and let me know if the issue still persists?
