Forms: Send emails from a custom domain! 🚀
You were eagerly waiting for this feature, and it’s finally here! We’re thrilled to introduce the opportunity to send email notifications in our Forms from a custom domain :rocket:
To enable this feature, please follow these steps:
Go to the Email Sender Settings on the Email tab
Click Add Email Sender
Enter your SMTP server details
All emails from the forms, including the Autoresponder, will be sent through this server:
After entering the details, the system will automatically check the connection. If the check is successful, the settings will be saved.
Voila! Emails will now be sent through your personal SMTP server :slightly_smiling_face:
Guys, have you tested the new feature? Share your experience in the comments - we’d love to hear from you :wink:
Back to Changelog →
Hi everyone,
I tested it with SSL port 465. It works perfectly. A milestone! Great! :raising_hands:
@Sina, Awesome, thank you so much for the feedback :wink:
Awesome :clap: my clients will love this new feature. Thank you :folded_hands:
Happy to hear that, @Lesan! Many thanks for the feedback :blush:
I tested it right away and it works perfectly, I’m really happy with it!
Is it also possible to include the first name of the person who filled out the form in the automatic email? I’m unfortunately not able to get that working right now.
Hi @user8320
This has always worked and actually has nothing to do with the new feature. But make sure you use the correct field ID for the text field.
grafik
Hi, @user8320 :wave:
Yep, Sina is right, here is the correct field ID - [voornaam:]:
Whoops, just spotted that I forgot the ': '. My bad! Thanks for pointing it out, guys!
No problem :wink:
Very happy about this. will this be an option to be added for bookings?
Hi @Richard_Bee :wave:
Thanks a bunch for the feedback! Currently, we don’t have any specific plans for adding this feature to the Appointment Booking app.
However, we agree that it would be an awesome enhancement and I’ve added this idea to the Wishlist - Send notification from a custom domain
If this idea gets more votes, we’ll try to consider it in the future :slightly_smiling_face:
Thank you, it makes sense since it is available in forms. Hopefully it should be a similar implementation for your team.
Hi! How can I add a e-mail sender to the calculator? And I also want to make integration with SendLayer API for sending. Possible?
Hi @Tom_van_der_Wal welcome to community :clap:
This isn’t possible for the calculator.
A request on the Wishlist would have to be created for this.
Ok, is the SendLayer API integration already possible for the forms?
Hi @Tom_van_der_Wal and welcome to the Community :wave:
The SendLayer integration isn’t available in our Forms, unfortunately. I’ve this idea and suggestion for the Calculator to the Wishlist on your behalf:
If they get more votes, we’ll try to consider them in the future :slightly_smiling_face:
Hi @Max is there, could there be a method of making the change Globally to all forms? I have ~190 to update. Or, would it be a matter of ploughing through and making changes to all forms on a one-by-one basis.
Many thanks, Phil
Hi there, @Phil :waving_hand:
Do I get it right that you’d like to use the same custom domain for all 190 forms?
