At the moment, when selecting an option from the dropdown in our Forms, you can change it, but it’s impossible to completely deselect it (leave it empty).
The good news is that we have a custom solution! Just add this code to the Custom JS section on the Settings tab of your widget’s settings and you’ll be fine ![]()
const WIDGET_ID = 'Your Widget ID';
new Promise((res) => {
let i = 0;
const check = () => {
if (component) {
res(component);
} else if (i !== 50) {
setTimeout(check, 100);
i++;
check();
waitForElement(`.elfsight-app-${WIDGET_ID} > div`).then(
(container) => {
container.addEventListener('click', () => {
const options = container.querySelectorAll('option');
if (options.length) {
Array.from(options).forEach((option) => {
option.removeAttribute('disabled');
Note: Do not forget to replace
Your Widget IDin the 1st line of the code with the ID of your widget
This video shows the feature in action:
Guys, was this solution helpful to you? Share your feedback in the comments ![]()
