For Carousel layout there is no option for set default number of item visible
hi team,
i am using this widget for my website, while playing around with the widget customization one thing i realized was when i use carousel feature it does not have option for no. of item visible, for example i want to show 3 items on default but there is no such option available,
could you plz let me know how can i achieve that? if any script for that then can i have the script?
Thanks.Regards
Hi there, @Dhiran_Khanal :wave:
If you’d like to set a total number of reviews to show, you can find this setting in the Filters section:
If you’d like to choose how many reviews are displayed on the 1st carousel page, you can do this with the Custom option for the Columns setting on the Layout tab:
I appreciate it.
Thanks i already have figured out ��
Regards,
Dhiran
Great, you’re always welcome :wink:
