Font customization
Allow user to upload their font and use it in all widgets
Hey there and welcome to the Community @Jacques_HANEN :wave:
I see that it would be great to have an option to upload fonts to the widgets. Could you please specify which widgets you primarily need this feature for?
As for now, you can check our CSS Codes category and find the needed code to change the font. If you haven’t found the code for your widget, just drop us a line and we’ll gladly help :wink:
Also, you can import fonts to the widget via Import URL option. This feature is not available in all of our apps, but it will work perfectly for the widgets you are using (Contact Form, Search, Reviews, Logo Showcase).
Thank you so much for your help, it works perfectly.
Best
Glad to hear that!
You are always welcome :wink:
Please could you add this to restaurant menu and events calendar
Hi there, @user1859 :wave:
The Import URL option is already supported in these apps. I see that you’ve tried to change the font to Belanosima in your Restaurant Menu, but you have the URL for Chivo Mono font:
To make it work correctly, you should replace it with the Belanosima font URL: https://fonts.googleapis.com/css2family=Belanosima:wght@400;600;700&family=Roboto:ital,wght@0,100..900;1,100..900&display=swap.
Here is how you can find the font URL:
Find the needed font and click Get font
Select Get Embed Code
Select Import, copy the URL and add it to your widget
