Flexible Positioning for Google Reviews Header
A useful improvement for Google Reviews integration would be the ability to position the header either above or below the reviews. Offering a simple setting to choose between “Top” and “Bottom” placement would provide businesses with greater customization and improve readability, ensuring better alignment with various website designs.
Hi there, @Tobias_Klass :wave:
Great idea, thanks for sharing! Let’s see if others would like to have such a setting too :slightly_smiling_face:
In the meantime, we’ll be happy to provide you with a custom solution. Would you like to place the header under the pagination (1) or between pagination and reviews (2)?
thanks for reaching out. I would like to place the header under the pagination (1).
All the best
Tobias
Wow, I’m really impressed by how quickly you guys reacted and provided the custom solution. Thank you so much! This is great!
Best
Tobias
Hi @Tobias_Klass :wave:
Yep, glad to hear that you like the result!
Just in case, here is the code we’ve added to the Custom CSS field on the Style tab of your widget’s settings:
.es-main-content {
  display: flex;
  flex-direction: column-reverse;
  gap: 36px
.es-header-component-top {
  margin: 0;
