Fix Consent text
the consent text shows up in upper case and bold text
Hi there, @backhome84 :wave:
I’ve checked your widget and the consent text isn’t bold and uppercase. However, if you’d like to achieve this, you can make the consent text bold in the settings:
And here is the code to make it uppercase:
[class*="choice-option__Label-sc"] {
  text-transform: uppercase;
If I misunderstood your idea, please elaborate on what you mean :slightly_smiling_face:
Check the widget on my website and you will see that the consent text is displayed the way I described.
Ah, I see it now, thank you!
There was an issue with the conflicting styles on your website and we’ve fixed it using this code in the Custom CSS field:
[class*="choice-option__ItemLabel-sc"]:last-child > div {
  font-size: 15px;
  font-weight: 400;
  color: rgb(17, 17, 17);
  text-transform: none;
[class*="choice-option__ItemLabel-sc"]:last-child > div > a {
  text-decoration: underline;
Please check your website and let me know if it’s fine now :slightly_smiling_face:
