Expand the range of trial days
1- Sería muy bueno para la gente que vive en américa del sur, que tiene menos recursos, podamos tener un tiempo extra o visitas extras.
2- Sería útil que el contador cuente ÚNICAMENTE las visitas únicas y no todas. Porque puedo estar trabajando en mi web y el contador vuela y pierdo todo el mes.
Thank you very much.
1- It would be great for people living in South America, who have fewer resources, to have extra time or extra visits.
2- It would be helpful if the counter counted ONLY unique visits and not all of them. Because I could be working on my website and the counter would fly by, and I’d lose the whole month.
Hi there, @Pablo_Arce and welcome aboard :waving_hand:
I have to say that our Community forum is English-based, so we communicate in English so that all the members understand what we’re talking about :slight_smile:
We don’t have a trial period, and you can use our widgets for free without any time limits. However, you’re right, there is a views limit.
The views were chosen as the main metrics in our service because each time the widget loads on the website, it also produces a load on our servers. So, each view equals one code loading.
Thus, we simply cannot remove this restriction or increase the current limits.
However, to make up for it, we decided not to restrict any of the widgets’ features and settings for any of our customers, even those who use the Free plan. We have done it specifically in order to let our customers test the widgets’ functionality in full, before making the decision about upgrading to a paid plan.
I hope this explains the reasons behind the view limit.
We also have special offers for non-profit organizations. So, if you’re non-profit, please check this article for more details - Special offers for Non-Profit organizations - Elfsight Help Center
Hola, entiendo que en este foro se hable en English, pero lo leo mejor de lo que lo escribo, por lo que yo escribo en mi idioma, y por lo visto, me entendiste!! :wink:
Sí, quise decir límite de visitas, pero es lo mismo: podrían ampliar ese rango para estas zonas.
Fuera de eso: para evitar sobrecargar los servidores y bajar el coste, lo que pueden hacer es justamente lo que hice yo, con ayuda del robot: HAcer una carga difereida, o Lazy Loading, hasta que el usuario no esté frente al pluggin.
De esta manera, el mes siguiente, cuando se reinicie el contador, las visitas inútiles no subiran innecesariamente si el usuario no llega al lugar donde se ve este pluggin.
Skypc.com.ar es mi web y podrán ver que también aproveche a hacer que cuando no se carga determinado archivo de esta empresa, porque no tengo más visitas disponibles, mi página web me mostrará enlaces hacía las reseñas de Google.
Lo importante acá es que con un Lazy les ahorraré un montón de carga inútil en el servidor. Pero si eso lo aplican nativamente, el ahorro de $$$ sería muchísimo mayor!!
Hi, I understand that this forum is spoken in English, but I read it better than I write it, so I write it in my own language, and apparently you understood me!! :wink:
Yes, I meant visit limit, but it’s the same thing: you could expand that range for these areas.
Aside from that: to avoid overloading the servers and lower costs, what you can do is exactly what I did, with the help of the robot: Lazy Loading until the user is in front of the plugin.
This way, the following month, when the counter resets, useless visits won’t increase unnecessarily if the user doesn’t reach the place where this plugin is displayed.
Skypc.com.ar is my website, and you can see that I also took advantage of the opportunity to make my website show links to Google reviews when a certain file from this company doesn’t load because I don’t have any more visits available.
The important thing here is that with a Lazy I’ll save you a ton of unnecessary server load. But if you implemented that natively, the savings would be much greater!
Me alegra decir que el atributo para la función de carga diferida está incluido en los códigos de instalación de nuestro widget de manera predeterminada, por lo que no necesita hacer nada adicional :slightly_smiling_face:
Glad to say that the attribute for the lazy loading feature is included to the installation codes of our widget by default, so you don’t need to do anything additionally :slightly_smiling_face:
Thanks for posting the answer in each language; I’ll do the same.
Regarding the current lazy plugin, the truth is… Either it’s a later implementation than when I started using it in 2023, or I don’t know why it doesn’t work for me. As I said, as soon as my page loads, the plugin loads immediately, so I recommended improving that detail.
But as I told you, in my case, I no longer need it because I implemented something more efficient, which directly avoids any type of connection to your server, except for the moment the user reaches the location of this plugin!
Thank you very much for responding! Best regards!
Gracias por poner la respuesta en cada idioma, haré lo mismo.
Respecto al lazy actual, la verdad es que.. O es una implementación posterior a cuando yo empecé a usarlo en 2023 o no sé por qué no me funciona a mí. Como dije, apenas carga mi página, el plugin ya me carga inmediatamente, por lo que recomendaba mejorar ese detalle.
Pero tal como te dije, en mi caso ya no me hace falta porque implementé algo más eficiente, que directamente evita cualquier tipo de conexión a vuestro servidor, exceptuando el momento en que el usuario llega adonde está ubicado este plugin!!
Muchas gracias por responder!! Saludos!!
¡Entendido, gracias!
Te refieres a la función de carga diferida; se implementó un poco más tarde.
Me alegra saber que has encontrado una solución que te funciona de maravilla. Para que lo sepas, también puedes habilitar la carga diferida para widgets antiguos (creados antes de su lanzamiento) añadiendo el atributo data-elfsight-app-lazy justo después del ID del widget :slightly_smiling_face:
Si tienes alguna pregunta en el futuro, no dudes en preguntarnos aquí. ¡Estaremos encantados de ayudarte!
Got it, thanks!
You’re about the lazy loading feature, it was implemented a bit later.
I am happy to know, that you’ve found a solution that works great for you. Just so you know, you can also enable lazy loading for old widgets (created before the release of lazy loading) by adding the data-elfsight-app-lazy attribute right after the widget ID :slightly_smiling_face:
If any questions come up in the future, feel free to ask them here. We’ll be happy to help!
Thanks very much!!
(Ya sé que no se escribe así!!!)
Saludos!!!
¡No te preocupes!
Si surge alguna otra cosa, estaremos encantados de ayudarte :slightly_smiling_face:
No sweat!
If anything else comes up, we’ll be delighted to help :slightly_smiling_face:
