On exit intent installed via header on webflow doesnt work it triggers as soon as the page loads
Hi @RB_Trading ![]()
I’ve shared this issue with the devs and will get back to you tomorrow ![]()
Our devs are investigating the issue, and I’ll update you once I have their response ![]()
Hi @RB_Trading, thank you so much for your patience!
The issue is fixed, could you please check your widget and let me know if it works as expected?
