Event Calendar: Print events or save them as PDFs
You can now print events directly from Event Calendar or save them as PDFs :tada:
Whether your visitors need a full event schedule or details of a single event, they can easily get a print-friendly version in just a few clicks.
Print the entire event schedule
The new Print button appears in the calendar header, next to the filters. It lets visitors print the event schedule based on their current search and filter selections — so they get exactly the events they’re interested in.
The print layout automatically adapts to the calendar view:
List, Carousel, Grid, Masonry, Slider
Events are printed as easy-to-read cards
Month & Week
Events keep their calendar layout, with one week per landscape page:
Day
Each day gets its own page:
To enable the button, go to Settings → Print Button and turn it on:
Print individual events
Visitors can also print a single event right from its popup. The printed version includes the event details without unnecessary interactive elements or the map, keeping everything clean and easy to read.
To enable this option, go to Settings → Popup Elements and check Print. The button will appear in the popup’s Share section:
Print or Save as PDF
Clicking either Print button opens the system print dialog, where visitors can print the content or save it as a PDF for later use.
On Android devices, the print-ready document opens in a new window.
Folks, did you like the new features? Share your feedback in the comments below :wink:
Back to Changelog →
A post was split to a new topic: Print button doesn’t work in Event Calendar
