The solution is really simple! Just add this code to the Custom CSS field on the Style tab of your Event Calendar widget’s settings and you’ll be fine ![]()
.eapp-events-calendar-layout-pastEventsTitle {
display: none;
And this script should be placed in the Custom JS field on the Settings tab:
const LISTEN_TYPES = {
one: {
validate: (node) => !!node
all: {
validate: (node) => node?.length > 0
function listenStep(args) {
args.node = args.select(args.selector, args.root);
if (!args.validate(args.node)) {
args.step++;
if (args.step < args.limit)
setTimeout(() => {
listenStep(args);
}, args.delay);
else
args.reject();
else {
args.resolve(args.node);
async function asyncListenFor(selector, type = 'one', customArgs = {}) {
const args = {
root: document,
node: undefined,
selector,
delay: 100,
limit: 50,
step: 0,
select: LISTEN_TYPES[type].select,
validate: LISTEN_TYPES[type].validate,
...customArgs
if (type === 'one' || type === 'all') {
return new Promise((resolve, reject) => {
listenStep({ ...args, resolve, reject });
asyncListenFor("#eapps-events-calendar-42efb307-9351-4bec-b3df-58d2c6a2dd0f").then(() => {
const container1 = document.querySelector(
'.eapp-events-calendar-layout-pastEvents .eapp-events-calendar-grid-component .eapp-events-calendar-grid-component'
const container2 = document.querySelector(
'.eapp-events-calendar-events-calendar-layout > .eapp-events-calendar-grid-component .eapp-events-calendar-grid-component'
const items1 = Array.from(container1.children);
const items2 = Array.from(container2.children);
items1.forEach((item) => container1.removeChild(item));
for (let i = items1.length - 1; i >= 0; i--) {
container1.appendChild(items1[i]);
items2.forEach((item) => container1.appendChild(item));
container2.remove();
Guys, was this solution helpful? Let us know in the comments ![]()
