Editable Calculation field
Hello,
I’m trying to create a mortgage calculator with an editable calculation field, means that the customer can type the number he needs and it will calculate instantly, is it possible to have the calculation field ont he right side?
Hi there, @Elio_Berberi :waving_hand:
With the Number field, you can let users manually input any numbers, but the results can’t be edited by users.
Could you please check it and let me know if the Number or Slider field options work for you?
If not, please describe why you’d prefer an option to let users edit results :slightly_smiling_face:
I’m looking for customers to have the downpayment calculated instantly and the option to edit in case they want to
Just to clear things up: you’re using the Slider field Down Payment for this case now, am I right (1)?
And to avoid using the calculation and a calculator field with the same name, you’d like to keep only the Downpayment calculation and let users edit it, is that correct (2)?
