Issue description: I would like to be able to edit the format of the picture in the Event Calendar widget, or at least be able to crop the photo to best suit the existing format.
Link to the page with the widget in question: I’m currently using another widget on my website because of this issue. OrlandoMusicLive.com
Max
October 22, 2025, 12:23pm
3
Hi there, @Chris_Gonzalez
This code should fix the image cropping issue:
.eapp-events-calendar-grid-item-imageContainer {
padding-top: 182%;
.eapp-events-calendar-grid-item-imageContainer img {
object-fit: cover;
Please add it to the Custom CSS field on the Style tab of your widget’s settings and let me know if it helped
That is an improvement…but images are still being cropped. I use square format in my current widget.
This is how it’s now appearing …when you click on the event it looks great, but from the main widget page not so much
Max
October 29, 2025, 3:10pm
5
Got it, thanks!
I’ve passed it on to the devs and will update you once I have their response
Max
October 30, 2025, 11:04am
6
The thing is that the images in your widget have different aspect ratio (most of them are 1/1, and some images - 4/5).
To adjust the images to a single format and fix the cropping issue, please use this CSS code on the Style tab:
/* image with aspect-ratio 1/1 */
padding-top: calc(100% + 64px);
/* image with aspect-ratio 4/5 */
.eapp-events-calendar-grid-item-imageContainer:has([alt="Picture for 'Hard Swingin' Country Soiree with Decker & Dimitrov' event"]) {
padding-top: calc(135% + 64px);
Here we’ve added the image with the 4/5 aspect ratio:
If you have more image with 4/5 aspect ratio, you should add them to the code using this format:
alt="Picture for 'EVENT_NAME' event".
Give it a try and let me know if it worked
