Dropdown layout
Hi again,
My calculator is getting very close. I was wondering if I can setup drop-downs in a row of 2.
I got this code from @Sina but it only worked with the choice radio buttons
[class*=“choice__OptionsContainer-sc”]{
display: grid!important;
grid-template-columns: 1fr 1fr 1fr!important;
gap: 0rem!important;
Thanks,
William
Hi there, @William62 :waving_hand:
Do I get it right that you’d like to apply it to the first 3 dropdowns (2 dropdowns in 1 line and the 3rd dropdown below)?
Yes thats what I’d like to try.
Thank you,
William
Our devs recommended using the code that will work on devices with the screen width from 800px, since this customization won’t look neat on the narrower screens:
@media(min-width: 800px) {
  [class*="form__FieldLayout-sc"]:nth-child(2),
  [class*="form__FieldLayout-sc"]:nth-child(3) {
    display: inline-grid;
    width: calc(50% - 5px);
  [class*="form__FieldLayout-sc"]:nth-child(2) {
    margin-right: 10px;
However, if you’d like to apply this change for all screen widths, you can use this code :slightly_smiling_face:
  margin-right: 10px;
Thanks again Max,
I’ve been playing around with it. perfect.
Thanks,
William
No problem :wink:
