Drop Down with Multiple selections
It would be awesome to have the option to utilize multiple selection from the drop down field. This way, the drop down shows only one field on the contact form, but the user can select multiple options from that drop down.
Only other option for multiple choice is by using the choice field and form gets muddled / lengthy if listing many choices at once (50 states for example)
Greetings and welcome to the Community, @Andrew_Howell :waving_hand:
Great idea, thanks for sharing! Now let’s see if it gets traction with other users :wink:
We need this function, as many forms have it. Let go and create the function, please
Hi @Web_Specialist :waving_hand:
Thanks for sharing your thoughts! If more users support this request, we’ll try to think it over in the future :slightly_smiling_face:
