Currently the Load More button appears only when # events > 10. But there is a setting for the number of events to display. I only display 5 at a time, for example. I’d like the Load More button when there are more than 5 events to display, that is to say when the number of events is greater than the number set to display.
Hello there @user12188 ![]()
Could you please send me a direct link to the page where your widget is installed, or just specify the widget ID?
I’ll be happy to check it for you ![]()
I’ve discussed it with the devs and, unfortunately, it’s impossible to customize the widget this way. I am really sorry!
I’ve moved your idea to the Wishlist and we’ll try to consider this option in the future updates ![]()
Thank you for your consideration.
A post was merged into an existing topic: Load More Events button in all layouts
