When I scroll through our website and reach the section where the map is located, it zooms as I scroll. I’d like to disable this so the page scrolls further, instead of zooming in on the map.
Hello there, @Marketing_Vandentop ![]()
Please try to add this code to the Custom JS field on the Settings tab of your widget’s settings and let me know if it helped ![]()
document.addEventListener(
'wheel',
(e) => {
if (e.target.closest('[class*="maplibregl-canvas-container"]')) {
e.stopImmediatePropagation();
true
