Data capture
can we have a dashboard with usage data of the calculator? I feel that many people use it and screenshot the result to not send the form. I would like to know if they are using it and what data fields are most used
Hi there, @Alex_G :waving_hand:
At the moment, it’s impossible to track user interactions with the calculator field. However, you can hide or blur results until the form is submitted.
These guides explain how you can do this:
Please check them out and let me know if these solutions work for your needs :slightly_smiling_face:
