Customize Dates Shown
Where it says in top left for example “Feb 14 - Feb 18” I would like to be able to do two things:
  1. Not show the end date and just show the start date, i.e. “Feb 14”
  2. Override the whole date for example so I can say “All Week”, or “Ongoing”, etc.
Hi @Neil_Collier :wave:
Unfortunately, there is no option to replace the date with the custom text. However, you can hide the end date in the event card with the help of this CSS code:
.eapp-events-calendar-date-element-endContainer {
  display: none;
Just add this code to the Custom CSS field on the Appearance tab of your widget’s settings and let me know if it worked :slightly_smiling_face:
Thanks! Is there some reference on all the CSS we can customize?
Glad to tell you that we have a CSS Codes category where you can find the most popular codes for different apps (including Event Calendar). Feel free to check it out - Event Calendar - Elfsight Community
