Ideally, I want to create my own template so that I don’t have to start from scratch each time I make a new pop-up.
My use case is that I would like to swap my pop-ups from time to time to add some variety to my website. The pop-ups should maintain the same style, but I might want to use a different image or text.
Hi there @Krimikeller_Rothenfe ![]()
We’ll try to think about adding the opportunity to save custom templates in the future. As for now, you can save a bunch of time with the Duplicate widget option:
Just click on the three dots next to the widget → click Duplicate :
