Custom CSS not working (but previously worked well)
  • Issue description:
Custom CSS not working and not applied to the weather widget. The custom css previously worked well but since 3 weeks ago it got problem and the css not applied. I never change the custom CSS. My concern is the width stuck at 300px and Nunito font is not applied.
My CSS:
@import url('https://fonts.googleapis.com/css2?family=Nunito:wght@400;700&display=swap');
.eapp-weather-weather-component {
    max-width: 500px !important;
    width: 100%;
.eapp-weather-forecast-component {
  margin-top: 46px;
.eapp-weather-detail-component {
  padding: 26px 24px 0;
.eapp-weather-weather-detail {
  font: 400 14px / 18px "Nunito", system-ui, -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Helvetica, Arial, sans-serif, "Apple Color Emoji", "Segoe UI Emoji", "Segoe UI Symbol" !important;
  padding-bottom: 15px;
  height: 232px;
Hi there, @retiarylime :wave:
We’ve fixed the issue with the width by adding .global-styles, at the beginning:
As for the font, it seems to be working correctly now. Could you please double-check it?
The width is working now. However the font still not changing to Nunito when viewing on android. It seems to fall back to system font.
Got it, thanks!
I’ll double-check it with the devs and update you later :slightly_smiling_face:
Seems like elfsight custom css unable to load imported fonts.
Hi @retiarylime :wave:
We’ve added this code to the Custom JS field on the Style tab of your widget’s settings:
(function() {
  const style = document.createElement('style');
  style.textContent = "@import url('https://fonts.googleapis.com/css2?family=Nunito:wght@400;700&display=swap');";
  document.head.append(style);
Please check your widget and let me know if the correct font is applied now :slightly_smiling_face:
It’s working now. Tq.
Great, you’re always welcome :wink:
