Creating a before / after slider widget for vertical (portrait) orientation photos
  • Issue description:
    I’ve successfully created a before/after slider widget using horizontal (landscape orientation) images in a 4:3 aspect ratio. Works great, showing the entire image.
When I try to create a before/after slider widget in vertical (portrait orientation) images in a 4:3 aspect ratio, the images are cut off so that the entire vertical image doesn’t show.
Is there a way to format the before/after slider to accommodate vertical (portrait) orientation images?
This link is to the successful horizontal image widget.
Thanks for the help.
Rad
Hey @Rad_Drew_Photography, happy to see you in our Community, welcome! :wave:
The issue with image cropping might occur if you’re using vertical images and selecting a horizontal Image Ratio, or vice versa.
To avoid this, when uploading vertical images, make sure to select an Image Ratio with the “(Vertical)” label in the settings:
For horizontal images, you can choose any of the other Image Ratio options.
If I misunderstood your question or if you were referring to something else, could you please create a widget with the images you’d like to display and share the widget name with me? That way, I can check everything for you and assist further :pray:
Thank you, Rena!
Dear @Rad_Drew_Photography, you’re always welcome! :smiling_face_with_three_hearts:
