Code for changing search font doesn't work
Shoot this isn’t working for me :frowning: - I need Questrial font and then Arial and a sans serif as backup and my search is still showing serifed fonts.
Hi there, @Lisa_Stein :waving_hand:
This code works only when you add one font to the widget. If you’d like to use multiple fonts as backup, please try to use this CSS code:
  font-family: Questrial, Arial, Helvetica, sans-serif !important;
Let me know if it helped :wink:
It looks like it worked on the elfsight side but not on my site:
Ah, sorry about that! Please let me double-check it with the devs.
I’ll get back to you tomorrow :slightly_smiling_face:
Here is the adjusted code we’ve added to your widget
body > div[class*="Popup__Container-sc"] * {
Please check your website and let me know if it’s fine now :slightly_smiling_face:
thank you!
You’re always welcome :wink:
