We need an option to show or hide specific fields based on clusters of conditions. For example, show a “Resolution” field if 1st cluster of 3 conditions together is met OR a 2nd cluster of 3 conditions together is met.
I’d like to see:
- Condition Flexibility - Ability to show/hide a line item using multiple conditions (e.g. if AND(A=1, B=2, C=3) OR (D=4))
- Can we show/hide features based on the total amount? For example, show question 6 if the price = $100
Thanks!
Ryan
Hi there, @user26019 ![]()
Thanks for sharing your thoughts with us!
Currently, there is no way to achieve this, but we have a similar idea on the Wishlist. I’ve moved your comment to the related thread, where we’ll keep you in the loop ![]()
