The solution is really simple! Just add this code to the Custom JS field on the Style tab of your Click To Call widget’s settings and you’ll be fine ![]()
const listenerBlock = (selector, callback) => {
const initialTargetNode = document.querySelector(selector);
if (initialTargetNode) {
return callback(initialTargetNode);
const mutationObserver = new MutationObserver((mutations, observer) => {
mutations.forEach(({ addedNodes }) =>
addedNodes.forEach((node) => {
if (node.nodeType === Node.ELEMENT_NODE) {
const targetNode = node.querySelector(selector);
if (targetNode) {
observer.disconnect();
return callback(targetNode);
mutationObserver.observe(document.body, {
childList: true,
subtree: true,
listenerBlock(".eapp-click-to-call-button-component", (button) => {
const link = document.querySelector(".eapp-click-to-call-window-phone");
button.addEventListener("click", (e) => {
e.stopPropagation();
link.click();
Guys, was this solution helpful? Let us know in the comments ![]()
