We are beyond thrilled to announce that the Custom JS option has been added to our Click to Call ![]()
With the Custom JS option, you can add extra features to the widget by writing your own script. You don’t need to reach out to our devs, as you have the freedom to customize it yourself.
Important: Custom JS operates only upon widget installation, but not in preview mode.
You can find this option on the Style tab:
Custom JS Editor has a Validate button, which allows you to check the code validity.
Reminder: the code entered is the body of the function that will be executed when the widget loads on the page. Do not include any <script> tags.
Guys, if any questions come up, don’t shy away to ask them in this thread ![]()
