How can I change the background color on the google review block from white to any choosen color and not just black as it seems to be only those two options?
Thanks Daniel
Thanks Daniel
Hi there, @Daniel_Massageterape ![]()
You’re referring to the widget with the Carousel layout, right?
If so, you can change the background color in the Background section on the Style tab of your widget’s settings:
Please try it out and let me know if it worked for you ![]()
Hi Max!
Thanks for you help but I’m using the Compact Badge Google Reviews, and its the color AROUND the Badge in looking to change. Thanks in advance for your help. Daniel
Got you, thanks!
This code will do the trick:
.es-layout-sidebar-container {
background-color: rgba(231, 231, 231, 0.53)!important;
Please add it to the Custom CSS field on the Style tab of your widget’s settings and let me know if it helped ![]()
Great THANKS!
But if I wanted to have a color in another format, HEX #F0F0F0
How could I add that? Its because thats what I am using on my website, and I would like it to be the same color. THANKS
You just need to replace rgba with the hex color code. Here is how it will look:
background-color: #F0F0F0 !important;
Give it a try and let me know how it worked ![]()
Amazing, Thanks so much for your help ![]()
It’s my pleasure ![]()
