Change hint background color
Add this code to the Custom CSS field on the Appearance tab of your Pricing Table widget’s settings:
.global-styles,
.es-tooltip-container {
  background: #d8d8d9 !important;
This doesn’t work for me… Here’s what I put into the costum CSS field:
//Hints
.global-styles,
  background: yellow !important;
Hi there, @Jesper_Jensen :waving_hand:
I’ve just checked your widget and the code works fine:
Weird.. It works now… Must have been some kind of delay. Thanx
Great, you’re welcome :wink:
