Change color of buttons in Podcast Player
this isn’t working - how to change this link color — i put this code in and nothing happened.
Welcome to the Community, @Dean_DiNardi :waving_hand:
As far as I understood from your chat with the AI agent, you’d like to change the color of the buttons, but not links in the description.
If so, this code will do the trick:
[class*="Icon__IconComponent-sc"] {
  fill: green;
Just add it to the Custom CSS field on the Style tab of your widget’s settings and you’ll be fine :slightly_smiling_face:
