Cars.com and Carfax Review Options
HI! I’m working with a number of car dealerships who are starting to utilize the review widget and the more sources of reviews available, the better. It’s nice to see Edmunds included, however Carfax and Cars.com also provide a huge resource for reviews as well and would be a great addition to the widget for the industry as a whole. Thanks for the time and consideration!
Hi there, @user19658 :wave:
Thank you so much for adding your idea to the Wishlist!
If more users upvote this idea to the Wishlist, we’ll try to consider it in the future. As a workaround, you can use a Custom Source option and add the needed reviews manually. Feel free to check it out:
Do you have a CarFax review integration? As a Toyota Dealership it would be great be able to show our CarFax review using Elfsight.
Hi there, @user26051 :waving_hand:
Unfortunately, this source isn’t supported at the moment, bur this idea is already on the Wishlist. I’ve moved your comment to the related thread, where we’ll keep you updated :slightly_smiling_face:
Thank you so much for the feedback and yes, welcome to the Community!
Are we able to add carfax.com review widget?
Hi there, @Internet_Manager :waving_hand:
Thanks a lot for the feedback!
We already have this source on the Wishlist. I’ve merged your comment with the existing request, where we’ll keep you updated :slightly_smiling_face:
Please add CARFAX as a review source.
Hi there and welcome to the Community, @user8234 :waving_hand:
Thank you for the feedback!
We already have a request for the Carfax source and I’ve added your comment there too. If we have any news from the dev team, we’ll update you right here :slightly_smiling_face:
