Calculator: How to add search for dropdowns with long option lists
Want to make searching the long lists of the dropdown fields in your Calculator widget simpler? We’ve got a solution!
Add this code to the Custom JS field on the Settings tab of your widget’s settings and the search will appear in dropdowns with more than 12 options:
const listenerBlock = (selector, callback) => {
  const uniqueBlocks = new Set();
  const initialTargetNode = document.querySelector(selector);
  if (initialTargetNode && !uniqueBlocks.has(initialTargetNode)) {
    uniqueBlocks.add(initialTargetNode);
    callback(initialTargetNode);
  const mutationObserver = new MutationObserver((mutations, observer) => {
    for (const mutation of mutations) {
      for (const node of mutation.addedNodes) {
        if (node.nodeType === Node.ELEMENT_NODE) {
          const targetNode = node.querySelector(selector);
          if (targetNode && !uniqueBlocks.has(targetNode)) {
            uniqueBlocks.add(targetNode);
            observer.disconnect();
            callback(targetNode);
  mutationObserver.observe(document.body, {
    childList: true,
    subtree: true
const createInput = (placeholder) => {
  const input = document.createElement('input');
  input.type = 'text';
  input.placeholder = placeholder;
  input.style.cssText = `
    width: calc(100% - 24px) !important;
    box-sizing: border-box !important;
    padding: 10px 29px 10px 15px !important;
    margin: 0px 12px !important;
    border: 1px solid rgba(17, 17, 17, 0.6) !important;
    border-radius: 4px !important;
    position: fixed  !important;
    top: 10px !important;
    left: 0 !important;
    background: inherit !important;
    z-index: 2 !important;
  return input;
listenerBlock('[class*="form__Container-sc"]', (formContainer) => {
  const dropdowns = formContainer.querySelectorAll(
    '[class*="dropdown__Container-sc"]'
  for (const dropdown of dropdowns) {
    const mutationObserver = new MutationObserver(([{ addedNodes }]) => {
      if (addedNodes.length) {
        const container = addedNodes[0];
        const dropdownContainer = container.querySelector(
          '[class*="Dropdown__DropdownContainer-sc"]'
        const withFilters = dropdownContainer.childNodes.length > 12;
        if (withFilters) {
          const filter = createInput('Search...');
          dropdownContainer.prepend(filter);
          dropdownContainer.style.position = 'relative';
          dropdownContainer.style.paddingTop = '60px';
          filter.addEventListener('input', (e) => {
            const value = e.target.value.trim();
            if (value) {
              dropdownContainer.childNodes.forEach((node) => {
                if (node.nodeName === 'INPUT') {
                  return;
                const isTarget = node.textContent
                  .toLowerCase()
                  .includes(value.toLowerCase());
                if (isTarget) {
                  node.style.display = 'flex';
                } else {
                  node.style.display = 'none';
            } else {
                  return;
                return (node.style.display = 'flex');
    mutationObserver.observe(dropdown, { childList: true });
Watch this video to see the code in action:
Guys, was this solution helpful? Let us know in the comments :slightly_smiling_face:
Wow, this is super helpful! :grinning_face_with_smiling_eyes: The search for long dropdowns makes things way easier. Thanks for sharing the code and the explanation — definitely going to try it out on my widget!
Hey there and welcome to the Community, @user29397 :waving_hand:
Happy to see you’ve found this solution helpful - many thanks for sharing your feedback with us :heart:
anything like this for forms?
Our devs will try to adjust the code, and I’ll let you know once the solution is ready :slightly_smiling_face:
Hi there, @user9527 :waving_hand:
Here is a solution for the Forms - Forms: How to add search for dropdowns with long option lists.
Give it a try and let me know how it worked :wink:
