Calculator: Bulk add multiple options in Dropdown and Choice fields
We’re glad to introduce an update that makes working with the Calculator easier. You can now add multiple options to the Dropdown and Choice field at once using the new Bulk Add feature :tada:
Previously, options had to be entered one by one. Now you can copy a full list from your notes or documents and paste it straight into the Bulk Add window.
This saves time and makes it much simpler to set up Dropdown fields with longer option lists:
Did you like the new feature? Let us know what you think in the comments :wink:
Back to Changelog →
