Button Spacing For Mobile
Are we able to adjust the spacing between buttons on mobile??
I do have the following custom CSS in effect but the more I “shrink” them, the further they get from each other:
@media(max-width: 500px) {
.global-styles,
[class*="ButtonBase__ButtonContainer"] {
transform: scale(0.9);
Its just the last page (since the submit buttons text is longer than “Back”
On the other pages of the form, they look good!
Hi there, @Taybraham :waving_hand:
This issue occurs because the text of the Submit button is quite long and it doesn’t fit the mobile container.
You can try to use a shorter text, for example “Submit Request” and reduce the font size of the button text using this CSS code:
    @media (max-width: 500px) {
      .es-button-base-ellipsis {
        font-size:15px
Please try it out and let me know if this setup works for you :slightly_smiling_face:
Thanks!
I ended up doing a hybrid of your suggestion! I made it so when on mobile the button reads Submit Request & reduces the size!
button[aria-label=“Submit Order Request”]
font-size: 0 !important;
.es-button-base-ellipsis::after {
content: “Submit Request”;
font-size: 16px !important;
It’s a little wonky if you look super close compared to the Back button next to it but still looks better than it running half way off the screen :slight_smile:
I see this, thanks for sharing a screenshot! Our devs will check what can be done here and I’ll update you once I have their response :slightly_smiling_face:
We’ve updated your CSS code and added it to your widget:
[class*='ButtonsGroup-sc'] {
    column-gap: 0px !important;
  button[aria-label="Submit Order Request"] .es-button-base-overlay::before {
    content: "Submit Request";
    text-wrap: nowrap;
    font-size: 18px;
    line-height: 24px;
  button[aria-label="Submit Order Request"] .es-button-base-ellipsis {
    display: none;
Check it out and let me know if you like the result :wink:
I appreciate it :slight_smile:
You’re always welcome :wink:
