Borderline Background for Before and After Slider
How can I set a Borderline for the background?
regards
Hey there @Sina :wave:
This code should do the trick:
[class*="Widget__Container-sc"] {
	border: 1px solid red;
Just add it to the Custom CSS field on the Style tab of your widget’s settings and let me know if it helped :slightly_smiling_face:
Hi Max.
you are the best :slight_smile:
it works fine
Great!
By the way, we’ve just launched a new challenge, where you can win a 3-month extension to your subscription (2-week bonus guaranteed).
The task is really simple: answer 3 simple questions about our new apps. Even if you are not using the new apps, you can just test them and share your experience with us!
Check the details and jump in - July Challenge: Share your thoughts about the new apps and win prizes! :trophy:
