Before and After slider Carousel Sets mobile view
When I add sets to my “before and after slider”, for the Carousel layout, it goes past the margins on mobile view.
It doesnt happen when its a single set, or if the sets are in the list layout.
Is there a CSS i can do so i can still have the sets but it fit the margins on mobile view?
example on page
https://www.sydneyepoxyfloors.com.au/metallic-marble-effect-epoxy-flooring-system
Hi there @Leva_Rasouli_Sydney :wave:
Your request is with our devs. I’ll get back to you once I receive a response from them :slightly_smiling_face:
@Leva_Rasouli_Sydney Thank you for waiting!
We’ve fixed the issue :slightly_smiling_face:
Check your website and let me know if you like what you see.
Thank you so much Max!
I copied the JS Script with the app code for the other widgets with sets, all of them working now thank you!
Great!
You are always welcome :wink:
