Audio Player - Background Music
I am using Duda platform.
Want a audio player that can loop.
web page with “multiple - buttons/track plays” each will start one track
so if I have 8 buttons on the page I can play 4 “tracks/buttons” simultaneously, on a single page.
So I will have 4 tracks playing all at once, each one on a loop.
Is this possible using either " Background Music" or another audio widget?
many thanks for your feedback. Tony.
Hi @Tony_Jones :wave:
We are so glad that you’ve decided to join us! Welcome :tada:
We’ll be happy to check if there is anything can be done. However, firstly, could you please provide some more details on your use case and specify the purpose for playing multiple tracks simultaneously?
The reason for playing multiple tracks is they are each aimed at different frequency pitch levels, and we need to blend the frequency tracks to match the right criteria for the situation.
Hope that helps
Tony.
Thanks a lot, Tony!
You know, I’ve consulted our developers and, unfortunately, there is no way to support the use case you described, I’m really sorry :frowning:
But probably we’ll be able to think about this functionality in the future, so thank you for bringing this to our attention :slight_smile:
