Appointment Booking CSS
On mobile only - I would like to remove the rounded corners in the pop-up modal and margin on top the top as well so it can fill the screen. Can you provide this?
Thank you,
Shawn
Hi there, @Shawn_Martin :wave:
Your request is with our devs now. I’ll update you once the solution is ready :wink:
We’ve added this code to the Custom CSS of your widget:
@media (width <= 540px) {
  [class*='Popup__PopupContent-sc'] {
    flex: 1 1 auto;
    height: 100%;
  [class*='Popup__PopupInner-sc'],
  [class*='Popup__PopupContent-sc'] .es-embed-root,
  [class*='layout__Container-sc'] {
    height: 100% !important;
    padding: 0 !important;
  [class*='WidgetBackground__Container-sc'],
  [class*='Background__Base-sc'] {
    border-radius: 0 !important;
Check it out and let me know if you like the result :wink:
Thank you. I’m now having an issue with the Google Sheets Integration on my “Hot Lead vrtz Request form” in the Form Builder. Can you have a look please?! It fires an error message when I trigger the Connect to Google Sheets button.
Thanks much!
Shawn Martin
FanYourLocal
3 posts were split to a new topic: Background customisation for Appointment Booking
