Hi. Can you create a widget that includes the animated number counter AND a progress circle with the percentage showing at the same time? (for example: on the left there is the animated number counter with an icon above it, then on the right there is a progress circle with a percentage) I don’t see one, unless I’m overlooking it. Thank you! ![]()
Hi there @Tamm_S ![]()
Do I understand right that our Number Counter app works fine for you, but you just wanted to add a progress circle there?
Hi @Max
Thank you for your reply. Yes, the Number Counter app works fine for me. I just wanted to add a progress circle there.
FYI - I’m attaching an image to show what I’m attempting to do.
Got it, thanks!
I agree that it would be a cool addition. Let’s see what others think about this option ![]()
