Tried to get Amazon reviews from Netherlands using https://www.amazon.nl/dp/B0CTFZC6TX but it fails with an error. Other Amazon locations I’ve tried seem to work.
Hi there @Joe_Sarkic ![]()
Yes, you are right! Currently, Amazon reviews from the Netherlands are not supported in our app. Here is the list of the supported domains:
We’ll try to consider the support of the Netherlands domains in the future. All the updates will be posted here ![]()
I see the UK is a supported domain, but I have issues with the UK. Using teh following link: https://www.amazon.co.uk/dp/B0CTFZC6TX
It gets one review and then hangs as processing continues without finishing.
Hi @Joe_Sarkic ![]()
I’ve checked your widget and see that the only review your source has is displayed and the processing is finished:
Could you please double-check it and let me know if everything is fine now?
