All-in-one review Widget not responsive on mobile devices
I am trying to find a way to fix the display of the widget on mobile devices. As I remember, scrollbars was visible a few day ago (still not the best solution) - but they are gone now!
Please advice :slight_smile:
[* Link to the page with the widget in question:] https://www.sonjagrillandwine.com/
Hi there @SoMe_Editor :wave:
Your request is with our devs now. I’ll get back to you once I receive a response from them :slightly_smiling_face:
We’ve fixed the issue by adding this code to the Custom CSS field on the Style tab of your widget’s settings:
.es-background-container {
  overflow: auto;
Please check your website and let me know if it’s fine now :wink:
It seems to have fixed the problem. The scrollbars are back on mobile.
Thank you for a quick response! :slight_smile:
No sweat :wink:
@Max it seems to be working good for me. It might just be a problem with the setup.
Hi @GalacticNetwork :wave:
I have to say that this issue is not related to the settings, as it is specifically for the Google Sites platform.
Anyway, thank you for your interest and help :slightly_smiling_face:
Alr
