Adjust spacing in event cards
Allow event width that does not add significant height to the event space. More mobile friendly format please.
Still too much gap between the event title and the details created. Does not limit the width to wrap to the next line
Hi @Mark_Armenta :waving_hand:
Just to make sure I understand your requests correctly:
  • On desktop, I only notice extra spacing in the first event card, where the start and end times aren’t displayed. However, the spacing seems larger on mobile. Are you referring specifically to the spacing in the mobile view?
  • As for the text wrapping, are you referring to the start and end times in the event cards? Would you be happy with the entire time range displayed on a single line? If not, could you please specify how many characters you’d like to fit on each line before the text wraps?
Since I am a new user, it’s not allowing me to attach any examples or a link to my website to show you.
Apologies about that! I’ve changed your trust level and now you should be able to attach examples and links :slightly_smiling_face:
Here is the link to my website where I use this widget. www.zodiac69.com I’m trying to eliminate the gaps as I show in the graphic attached. It is especially bad in a mobile view. The gaps are huge.
Thank you for your quick response. It is much appreciated.
Got it, thanks for sharing the details!
We’ve removed these padding using the CSS code below:
.eapp-events-calendar-list-item-component {
  padding-top: 12px;
  padding-bottom: 12px;
.eapp-events-calendar-list-item-date {
  margin-top: -12px;
  margin-bottom: -12px;
  padding-top: 12px;
.eapp-events-calendar-list-item-locationAndTime {
  margin-top: 6px;
.eapp-events-calendar-list-item-locationAndTime:empty {
  display: none;
.eapp-events-calendar-list-item-description {
  margin-top: 6px;
@media (max-width: 600px) {
    margin-bottom: 12px;
Please check your website and let me know if you like the result :wink:
Thank you Max. You ROCK!! I’ll give it a try. Thank you for the fast response. Have a great Thanksgiving Holiday.
Mark
It’s my pleasure!
Just in case, I’d like to note that this code is already saved in your widget, so you won’t have to do anything additionally.
If you have any further questions or any assistance is needed, we’re always here to help!
Have a great Thanksgiving Holiday :blush:
