Max
Add this code to the Custom CSS field on the Settings tab of your Calculator widget’s settings:
[class*="results__Container-sc"] {
gap: 15px;
Guys, if this code was helpful to you, please drop a line in the comments. Your feedback helps us improve our services and provide better solutions
Thanks for this code. As I streamline the look is there css code for dropdown padding and spacing between elements?
Thank you,
William
I figured out the dropdown padding, that helps.
[class*="dropdown__Select-sc"] {
border-radius:10px; padding:5px !important;
Max
4
Glad to hear that you’ve found a solution - thanks for sharing it with us!
If anything else comes up, we’re always here to help
