Add to "Minimum Age" at settings section 16 years also instead of only 18 and 21
At the moment only 18 and 21 can be selected. Please add to the “Minimum Age” at settings section “16” years also as an option. Thanks!
Hey there @TomorrowBits_GmbH :wave:
Glad to tell you that you can add the needed age manually:
Wow, awesome!!! :slight_smile: Thank you very much!! :+1:
It’s the least I could do :wink:
If anything comes up, I am always here to help!
2 posts were merged into an existing topic: Translate Date Format
A post was split to a new topic: Translate Date Format
