Add Add to cart to transform the website into a store from which customers can purchase
Hi there, @muaz_Abdallah ![]()
Thanks for adding your suggestion!
Are you looking for the button that will redirect users from your website to the existing store on click? Or would you like to build a store using a widget?
Any additional info would be much appreciated ![]()
