Add tabs/categories feature
It would be great to use tabs for the widget, which will let to divide certain files into categories. :slight_smile:
Having the ability to categorize PDFs would enable us to create organized document libraries rather than maintaining a single list of documents. For instance, I currently need to create multiple widgets just to separate board minutes by year, among other distinctions.
Hey there, @Janeiro_Blackmon and welcome aboard :wave:
Many thanks for sharing your thoughts!
We already have a similar suggestion on the Wishlist and I’ve merged your comment with it :slightly_smiling_face:
Have a list of categories at the top which viewers can select to reduce the list of PDF docs visible
Hi there, @TheAndies_Limited :waving_hand:
Glad to say that this idea is already on the Wishlist! I’ve merged your comment with the existing request, where we’ll keep you updated :slightly_smiling_face:
Thanks for sharing your thoughts and yes, welcome to the Community!
