Add RTL to Masonry layout
The text and icons inside the review boxes are loading RTL fine with CSS codes. However, the physical layout of the widget itself is not.
You will notice the AI generated is on the left, it should be on the right in Arabic. Also the reviews are arranged to start from the left to right, it should be from right to left in Arabic.
Currently, the built-in RTL setting is included in the Slider or Carousel layouts only. I’d like to have it for other layouts too
Hi there, @Tariq_Obaid :waving_hand:
Nice idea, thanks for sharing! We’ll have it in mind and see for more feedback from other users :slightly_smiling_face:
