I know that the TikTok widget has the ability to change the header’s font size, etc. but the Instagram widget doesn’t have that. This should really be added!
@user991 thanks a lot for your idea!
Agree, more customization options never hurts, and I hope our devs will find a way to make the Header section more flexible ![]()
And if you have any ideas on particular options you’d love us to implement, please do share in the comments, we’ll be happy to consider them all!
Hey everyone!
We’re excited to share that now you can change the title styling right in the settings:
This feature is available in widgets created after this release only.
You can manually update your existing widget from the dashboard, but please note that any custom CSS or JS code currently added to the widget will be removed during the update.
Want to move to the latest version while keeping your custom CSS or JS? Leave a comment in this thread — our developers will be happy to help
Find more new features in this post: Instagram Feed: [MAJOR UPDATE] Tags & Mentions, advanced filtering, new layouts, styles and more! ⚡
